March 12, 2021 at 4:20 am
AndyJP
SubscriberSince it is hard purchasing a lot of top-class Quadro/Tesla boards per every workstation, and equivalent GTX boards are not supported, I was thinking about remote execution.nnThere is a thing called rCUDA, a CUDA server that transparently and dynamically allocates local NVIDIA CUDA boards to remote clients executing CUDA code.nThe only requirement is that the software should have CUDA library linked dynamically at runtime (for substituting the CUDA library with a client wrapper).... And obviously, it should not check the GPU version, since it may see something weird instead of Quadro.../Tesla...nnSo was it tried in ANSYS or by anyone?n -
March 15, 2021 at 2:06 pm
Randy Kosarik
Ansys EmployeeHi AndyJP, nrCUDA has not been tested with ANSYS products.nAdditionally, I have not located any references to other customer inquiries regarding rCUDA.nthanksnRandyn -
March 15, 2021 at 3:54 pm
AndyJP
SubscriberDefinitely not many RF customers know about rCUDA. It is a modern deep learning HPC thing. But you could offer its support as a valuable feature. Every developer searches for cost-down, and this would offer a serious cost down without ANSYS loosing anything. CUDA licenses are linked to HPC, so there will be no reduction in license purchase. Instead, funds can be rearranged for more ANSYS licenses.n
- Maxwell, HFSS or Q3D?
- Error
2702
2138
1355
1144
462
