May 24, 2022 at 4:00 am
jennylili
SubscriberHi, I have a question
The top comment on the Lifehacker page linked below suggests keeping a spare capacitor on hand to replace if it fails, presumably if you're handy enough to do it (I like to think that I am, I know how to bleed a capacitor, etc.).
I have read the blog:
https://www.apogeeweb.net/electron/how-to-test-a-run-capacitor-with-a-multimeter.html
Do these truly degrade after around 5 years? Is this a feasible plan?
My heat pump is a Mitsubishi Hyper Heat P-series, model PUZ-HA36NHA4, and the capacitor appears to be R01 E22 255 MAIN SMOOTHING CAPACITOR (but I'm having difficulties finding one).
Thanks in advance for your suggestion
May 24, 2022 at 9:29 am
Chinmay T
It looks like the question does not belong to simulation related but on physics (spare capacitor).
So as Ansys employees, we may not be able to provide you correct advice.
We will leave it to the forum community who can guide you better.
Thanks Chinmay
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
