Is it necessary to have node coincidence between bonded surfaces?
    • muruep00
      I have this steel structure. I have a friction contact between the beams, and a bonded contact between the welds and the beams. Do I need node matching between the nodes of the beam and the nodes of the welds for an optimal solution?
      No node merging
      No node merging between welds and beam
    • Aniket
      No it is not required. But it would be good to have a similar mesh size.
