3D Design
3D Design
Is it posible to have boolean between solid and surface body in design modeler?
    • Tayyaba
      Hi all,
      I am attaching my geometry, I have a surface body in the middle (points-lines-surface). I have to subtract this surface body from the rest of fluid domain as I have to give different boundary conditions at the bottom so I need three faces at the bottom: two from fluid domain and one from the surface body.
      when I use boolean operation although it is done but I do not get three faces at bottom, I have just one like at the start.
      Is is possible to subtract the surface body from the rest fluid domain?
      Regards
      Tayyaba
    • Tayyaba
      Is it suitable to use boolean-Imprint faces?instead of boolean-subtract?
      Tayyaba
      Use Imprint. Boolean won't work as the surface has no volume to overlap with the fluid region.
    • Keyur Kanade
      You can use imprint.
      Or you can create a single part of surface body and solid body and then use sharetopology.
      Keyur
    • Tayyaba
      Thank you very much for your kind replies, for my case imprint goes well because by share topology I am unable to select the faces separately for different boundary conditions.
      Regards
      Tayyaba
Viewing 4 reply threads
