March 4, 2022 at 9:04 pm
pascal_NQ
SubscriberHi,
I need to do an overlapping integration of the electric field between two eigenmodes, but from what I know, it is not possible to do this in the field calculator since only one mode can be used at a time. Also, I cannot simply export calculation from a 3d grid since my design have a very large aspect ratio, and so the exported filed would be to large with a step size small enough to grasp small features. If I could have access to the nodes point of the solution's mesh I could export field only at those point for the 2 desired modes and compute the overlapping integral in an external tool.
Thank you in advance!
Pascal
March 14, 2022 at 4:55 pmPraneeth
Please note that you can only find the available modes in a model using the Eigen mode solver.
If you want to see multiple modes at the same time, then I would suggest you to add excitations in modal network solution.
With this you can do the required analysis across different modes.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2508
2064
1277
1088
456
