Is it possible to assign different wall name to already existing one after completion of simulation?
March 3, 2022 at 9:45 am
KSD
SubscriberBefore running simulation in fluent, I have named all the wall boundary edges as Wall. And transferred to Fluent.
But now after completing my simulation, I realized that if I had given different wall names for different section of wall, then it would be easier to do post processing of that specific part of wall using polyline intersection tool.
For e.g. This is how I gave all edges of a domain with same name as wall
March 3, 2022 at 10:53 amKeyur Kanade
Ansys EmployeeUse domain  zones  separate. Then you can have different walls. No need to run it again.
Please go through help manual for more details
Regards Keyur
March 3, 2022 at 11:13 amKSD
SubscriberSir, thank you. After reading your answer I got the the tag word to search for and found the help in YouTube, (" target="blank">), using region how they are separating a wall.
But still here I have to specify the region then use separate, isn't it possible to do something similar to like again renaming the edges in Ansys meshing and then assigning the BCs in fluent without interrupting the solutions.
I mean can I do something similar to this instead of marking a region or specifying the coordinates.
March 3, 2022 at 11:38 amRob
Ansys EmployeeYou will need to pause the solution, split the edges and then resume. Or you can alter the mesh and read it back in, then interpolate the data before running on. I'd use the split option in Fluent. As you have an angle or gap between the wall sections you can split by angle too.
March 4, 2022 at 7:54 amKSD
SubscriberSir, Yes sir. Interpolating the existing solution to newly defined named boundaries mesh file is much faster. Thanks a lot for the help.
Viewing 4 reply threads- You must be logged in to reply to this topic.
2620
2098
1327
1110
461
