December 1, 2020 at 7:31 am
evandevlieger
SubscriberDecember 1, 2020 at 12:54 pmpeteroznewman
SubscribernI understand you are not interested in the seesaw, but it is required to get a proper mechanism of the two pads. In Mechanical, under Geometry, select the seesaw body and in the Details window, set the Stiffness Behavior to Rigid. This allows the seesaw to be present but requires almost no nodes and elements to provide the proper DOF to the mechanism. Now you can create three Revolute Joints. One on each pad at the pivot holes, and one Revolute joint Body-Ground to allow the seesaw to pivot at the center. nViewing 1 reply thread- The topic ‘is it possible to connect multiple remote points with one another and define each DOF separately’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1688
1478
