July 30, 2018 at 11:28 am
KumarVaibhav
SubscriberI have an enclosure cube and a midsurface file can i create a boolean for a fluid domain by subtracting the two?What should i do?
July 30, 2018 at 12:51 pm
SubscriberYou should bring just the midsurface into DesignModeler and use the Enclosure tool to create the enclosure.
August 2, 2018 at 10:36 am
Samir Kadam
Ansys EmployeeTo append Peter's comments, in DesignModeler, once you create Enclosure for the Midsurface, it will have two bodies in the tree - one surface body and one solid body. You will need to select those two bodies, right click and Form New Part.
This will enable Shared Topology between them. And once you take it to Mesher, there will be single solid body with imprinting of Midsurface in it.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
