January 23, 2018 at 11:07 pm
dural
SubscriberHi everyone, my question is already whole said in the topic title. Is it somehow possible to create journal file backwards from used functions? I mean, like suppose I have set everything and I am ready to run calculations. However, I have to use the same boundary conditions/etc/etc more times. Are these functions saved somewhere? In some temporary folders or whatever.I am really curious..thanks!
edit: to be more precise, I have found this, but I am not sure if its also working when it is not workbench ( I dont have ansys near me for few days)
Record Journal File: Specify if a journal file should be recorded. If this check box is selected, ANSYS Workbench writes a journal file (.wbjn) for each ANSYS Workbench session and the following options are enabled:
Journal File Directory: Select the directory to which journal files should be written.
On Windows, the directory preference defaults to %TEMP%WorkbenchJournals.
On Linux, the directory preference defaults to the following, in order:
$TEMP/WorkbenchJournals
$TMP/WorkbenchJournals
$HOME/.ansys/WorkbenchJournals
If you record a session (File> Scripting> Record Journal) for future playback, the same information is written to both the location specified here and to the file specified when you begin recording.
- unable to open files in ansys
- How to move duplicated ansys project position in workbench GUI
- Download MATLAB toolbox AnsysAAS
- An unknown error with memory occurred during solution.
- Desginpoints in Ansys 18.2 workbench got stuck at the stage of updating model in static structural
- Error: Unable to open some designs in this project – Corrupted project files
- Ansys solving system coupling problems on a remote cluster does not provide constant results.
- ANSYS Multi field 2-way FSI data coupling issue
- Material constant Damping calculation
- Different initial temperature conditions for two different object in transient-thermal
2524
2066
1285
1096
459
