October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeYes. The following APDL commands demonstrate how to define multiple loads using *do loop; Fini /clear /output,out,out *cfopen,load,txt *Do,i,1,2 *DIM,BF%i%LOAD,TABLE,3,1,1,time, BF%i%LOAD(1,0) = 0,0.5,1 BF%i%LOAD(1,1) = %i%*10,%i%*20,%i%*30 *vwrite,i,i bfv,%i,hgen,%%BF%iLOAD%% *enddo *cfclos !create Solid model and mesh it /prep7 mp,kxx,1,50 mp,dens,1,7850 mp,c,1,450 et,1,70 block,,10,,1,,1 block,10.1,20.1,,1,,1 esize,.3 vmesh,all /inp,load,txt /solu ANTYPE,4 TRNOPT,FULL LUMPM,0 TIME,1 solve /post1 /EFACET,1 PLNSOL, TEMP,, 0
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
