July 29, 2019 at 8:36 am
Doba
SubscriberLets say I want a disc shaped porous medium with 3mm thickness and 15mm radius but with holes of a certain shape and size (lets say squares with 3mm^2 area)
Possible?
July 29, 2019 at 1:45 pm
Ansys EmployeeIf you read up on the porous media functions you see it's a lumped model to mimic a pressure lost caused by "stuff" in the flow volume. So, I can calculate the effect of square, round or oval holes in a plate and get the same resistance coefficients depending on hole size & spacing.
Please read through the section of the manual: if you can't use the thin plate equations to determine a resistance coefficient you'll need a sub model.
2726
2156
1359
1150
462
