Tagged: ansys-spaceclaim, compound-semiconductor, metal
January 5, 2022 at 2:38 am
Hailey_Kim
SubscriberHi,
I'm new in Ansys program. I've heard that it is possible to simulate thermal analysis with Ansys Workbench.
i have 2D designs for HEMTs(High electron mobility transistor) and MOSFETs.
When i fabricated AlGaN/GaN HEMT in person, i used ohmic metal Ti/Al/Ni/Au. I wonder when i convert 2D designs to 3D designs with Ansys spaceclaim, Do i have to make ohmic metal each layer? for example first layer for Ti, second layer for Al, etc..
Also, i wonder it is possible to designate the polarization for creating 2DEG(2-Dimension Electron Gas)
plz, Help me if there is somebody who has experienced to design compound semiconductor to thermal analysis with workbench
i need your help
best regard,
Hailey
July 26, 2022 at 6:45 pmRahul Kumbhar
Ansys EmployeeHello @Hailey_Kim
Could you please elaborate more? From what I understood, you have metal bodies and non-metal bodies in each layer. These are all 3D bodies. Correct me if I am wrong here.
You can use Steady State Thermal analysis system in Workbench. In the Geometry cell, you can import tis Spaceclaim model. In Thermal analysis, you can use contact between bodies or in Spaceclaim you can create ‘Share topology’ so when meshed, they create shared nodes between separate bodies. You might also need to use Boolean operation in Spaceclaim to remove overlapping volumes if any.You may check these courses.
Intro to Heat Transfer | Ansys Innovation Courses
Thermal Conductivity in Heat Transfer | Ansys Innovation Courses
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
Trending discussions- Signing up as ANSYS Support Coordinator
- Maxwell, HFSS or Q3D?
- Error
- Feeding experimental data (temperature) in to Ansys to get conductivity
- Illegal External Terminal – assigning current to a coil
- An Error Encountered During the Simulation in ANSYS 17.1 workbench
- Failed to recover curve outlines
- meshing problem
601
560
220
182
120
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
