Is it possible to disconnnect system coupling and Transient structural from fluid flow in FSI?
    • Tayyaba
      Hi
      I hope you are doing well, I am currently working with Fluid Structure
      Interaction (FSI) using Ansys Workbench . My
      question is as follows:
      in coupled FSI I use the following:
      1. Geometry
      2. Transient Structure
      3. Fluid flow
      4. System coupling
      is it possible to disconnect transient structure and system coupling
      from Fluid flow at certain time and to see the influence of only Fluid
      flow?
      Waiting for your kind response.
      Regards
      Tayyaba Bano
      You can take data from Fluent (pressure, temperature etc) from Fluent into Mechanical and use that. Is that what you want?
    • Tayyaba
      Thank you very much for your kind reply,  if I want to see only fluid influence for certain time without structure motion  just in the case of CFD , then is it possible by Ansys Workbench to shift FSI to CFD, by disconnecting the system coupling and transient structure from fluid flow?
      Kind regards
      Tayyaba
