Ansys Products
Ansys Products
Is it possible to export all TimeSteps as .STL at once
    • Maxime Daniel
      I'm trying to make a realistic rendering with Keyshot from a simulation made with Mechanical.
      But the process is awful, i have to select each step of the result, and then export it manually into an STL file.
      Which is very very long with 200 steps in the end.
      Is there a way to automate this process ?
      Thank you 🙂
    • Aniket
      You can use ACT scripting for this.
      Please check snippet here:
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/act_script/act_script_examples_export_result_object.html
      -Aniket
    • Maxime Daniel
      I'm sorry i can't access this link since i'm using a student licence
