Is it possible to export nodes and conectivities of a mesh in an organized way??
    • Diego Quexada
      Hello! I'd like to know if I can use APDL commands in Mechanical to export nodes, connectivities, and named selections as a fixed arrangement of columns. I am using MECHANICAL to mesh and export some models that I use on my own FEM code.I would like to know if I can export the named selections for example as an arrangement of fixed columns, I have used the export tool, but I want to define a specific format to export.
      Any help will be highly appreciated!
      Thank you!!
    • Aniket
      Forum Moderator
      Have you checked Ansys Store Multi Object ExportV1.1 created by Ansys Inc ? you may need to change it a bit to suit your needs, but the extension should work. And it also includes source code.
      -Aniket
      Forum Rules & Guidelines
