February 10, 2023 at 1:58 am
Rajeev Devaraj
SubscriberI am wondering if it is possible to do similar functions as in the MAPDL (in the video) to define the interface between rebar and concrete in the Workbench. If yes, How??
February 10, 2023 at 9:35 am
Erik Kostson
Ansys EmployeeHi
Workbench (wb) is another say pre-processor for the apdl solver. So in the end (when we aredone with our model) it will generate a ds.dat that is then run (solved) by the apdl solver. Finally we post-process in Workbench again once the solution is finished. So it uses the same apdl language/syntax (see in the ds.dat file that it creates), hence why we can also add apdl command snippets into wb/mechanical
Hope this helps
Erik
3638
2502
1729
1224
578
