Tagged: bolt-pretension, pre-stress, static-structural
May 31, 2022 at 5:53 am
hmertd
SubscriberHello everyone I can perform pre-stressed modal or transient analysis using ANSYS Mechanical. However, I cannot use bolt-pretension results in another static analysis. I have a case that, same pretension with plenty of different loads, if I can solve bolt-pretension once, than I will save so much time.
May 31, 2022 at 7:03 am
July 1, 2022 at 4:59 am
mert.dedebeyoglu
SubscriberI tried your suggestion. However, exported stresses does not match with original analysis and I have convergence issues.
I exported Eqv. Von Misses stress as a text file. Than I imported as initial stress.
March 12, 2023 at 5:57 pm
Miguel
SubscriberI am also interested in this question. Anybody else there with new ideas?
Thanks
March 12, 2023 at 7:36 pm
SubscriberI wrote about a method I used a long time ago in this old thread.
https://forum.ansys.com/forums/topic/multiple-loads-restarted-from-initial-loadstep/
March 12, 2023 at 9:09 pm
Miguel
SubscriberThanks Peter but following your link, neither the embedded videos nor the attached archive seem to be available... Is there any other way to access them to properly understand your explanations?
March 12, 2023 at 10:25 pm
SubscriberYes, that is a 4 year old post and the videos and archive have been deleted.
The description should be sufficient to recreate the workflow.
Do you know how to restart a normal solution? Master that as a first step.
March 12, 2023 at 10:47 pm
Miguel
SubscriberFair enough. I´ll try it. Thanks.
Anyway, my interest in this case is in relation with this other post about how to evaluate several cycles of a loading setup (in my case 20) but not so many as to make sense to apply fatigue tools:
https://forum.ansys.com/forums/topic/low-cycle-fatigue/
I thought this “Static to Static” approach could be one way to go about it… Do you have any suggestion/s on this particular matter?
3670
2552
1751
1226
582
