Is it possible to recover Design Modeler geometry files from a hard crash, for example, if there was
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeMaybe. You can try the following approach. Open File Explorer and enter %temp% in the command line and then search for file type *agdb. You should see several files with names like: XXXX.agdb-0 XXXX.agdb-1 XXXX.agdb-2 XXXX.agdb-3 The DesignModeler Auto-save feature creates these files. You can review these files to determine the latest saved version.
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
2706
2146
1357
1148
462
