May 11, 2021 at 1:48 pm
vinaychandrakar11
SubscriberI am trying to simulate normal fluid flow in a cylinder with two different inlet temperatures. Case 1 is with 500K and Case 2 is at 750K. I am able to do it individually for case 1 and case 2.
I would like to know that is it possible to do two simulations in one run because it will reduce my computational time, if other boundary conditions except one (here temperature) remains same and geometry and mesh is also remain unchanged.
Please see the image.
May 12, 2021 at 7:00 amKeyur Kanade
Ansys EmployeeMay 12, 2021 at 5:31 pmvinaychandrakar11
SubscriberI would like to know the ways of doing it. Can you help me with this?
May 13, 2021 at 6:54 amKeyur Kanade
Ansys EmployeeSame as do it for one cylinder. Define BCs and run it.
Regards Keyur
May 13, 2021 at 4:58 pmvinaychandrakar11
SubscriberI think you didn't understand the question clearly. I clearly mentioned that I want to know the ways to perform two simulations (case 1 and case 2; two different inlet temperatures) in one run not two different simulations. I hope now you will get it.
May 14, 2021 at 9:39 amRob
Ansys EmployeeSet the boundary condition in each tube separately. I'd run two sequential calculations as it's quicker and far more difficult to get muddled up later.
May 16, 2021 at 4:15 pmvinaychandrakar11
SubscriberOkay, it means there is no way to do both simulations in one go.
May 17, 2021 at 8:29 amRob
Ansys EmployeeYou can run as we suggested above using different boundary labels but risk confusing yourself and the solver. Or run sequentially (single licence) or buy multiple licences and run several at once. I have 10 solver keys (staff licence) so could run 10 models at once: as I only have a 4 core cpu that wouldn't be very efficient.
April 19, 2022 at 4:49 pmMonster7c
SubscriberRight click on solution and use the "duplicate". It will clone everything. Then, change the boundary condition for that one. Then, you have two boundary condition in one simulation.
Viewing 8 reply threads- You must be logged in to reply to this topic.
2706
2146
1357
1144
462
