Is it possible to use a final solution as initial conditions in a new simulation?
    • DanielOliveira
      Good afternoon,nI'm performing a 1-way FSI simulation with Fluent and Transient Structural. nI would like to know if it is possible to start the System Coupling only after 5 s (for example) of fluid flow simulation in Fluent? Or there is any way to simulate separately the Fluent simulation and then use the solution at 5 s as initial conditions for the FSI analysis?.Really appreciate any helpnBest Regardsnn
    • Surya Deb
      Hello , nI think you can make use of External Data to write out the data at 5 seconds from Fluent and then read it in Transient Structural. nYou can check the External Data capability in WB.nYou will find more information here.nRegards,nSuryan
