February 7, 2022 at 9:30 pm
oyesilyu
SubscriberHello,
I have been using Lumerical RCWA recently and it works really nice. I was wondering if we could use anisotropic materials with it. I attempted to use them but the results clearly took one of the axis dispersion curve and calculated accordingly. If it is possible to do this, could you briefly describe it?
Thanks,
Omer
February 10, 2022 at 12:18 amGuilin Sun
Ansys EmployeeThankyou for trying our new RCWA solver. Currently it is still under intense improvement and has no anisotropic capability. Please keep an eye on the release news which declares new features.
February 10, 2022 at 12:20 amoyesilyu
SubscriberThank you so much gsun, I have one more question if that is okay. Can we implement substrates in the RCWA?
Thanks Omer
February 10, 2022 at 4:07 pmGuilin Sun
Ansys EmployeeI believe so. You can try just a substrate and see if the result is ok. I have not used it yet.
October 17, 2022 at 12:24 pmoyesilyu
SubscriberHello,
I see we have a separate RCWA interface for Lumerical now, which is great! I was wondering if the we could use diagonal anisotropic materials in RCWA simulaitons?
Best,
Omer
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Why am I getting “process exited without calling finalize”, and how do I fix it?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5364
3363
2471
1310
1018
