Is my geometry correct for wind loading on solar panel located on rooftop?
    • Ansysstudent5361
      I'm looking at wind loading on rooftop located solar panel. I wanted to ask if my geometry was correct for the modelling. This looks like what I want but functionally is there anything I should do? Should I separate the solar panel and building as two solids? What are some best practices for geometry creation so I can mesh this easily and get accurate results? I have not created my fluid domain yet but its just an enclosure with domain dimensions taken from literature. I'm asking this because my previous model was a real pain to mesh and did not mesh properly so I started from scratch again. Can someone guide me on meshing this?
    • Keyur Kanade
      If I understand you question correctly, then please use single solid. nRemove that small thickness of solar panel. Make it planar with roof. nThen create fluid volume. nThen use 'Groups' in SpaceClaim. Create a group for the face of solar panel. This will come in as Named Selection in Meshing. nOnce you create fluid volume, please go ahead with tet + inflation meshing. nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help links
    • Ansysstudent5361
      Hi, nThank you for replying. What if i wanted a different orientation of the panel with respect to the inclination of my roof? My model currently is a single solid but I want to keep the panel elevated from the roof at a slightly different angle as to that of the roof. Thanks.n
      I would make a solid for the building (and then subtract from the domain) and a solid for the panel and region between it and the roof. The surface where the top of the panel is will be a wall, the volume between it & the roof will be fluid. No need to give the panel a CAD thickness unless you really want to add that much mesh to the domain. n
    • Ansysstudent5361
      Hi,nJust to clarify, I can create a base building model (solid) and subtract it from the domain. Then, i could create a volume on top of my base building , create a named selection on the surface of the volume (to create panel) and when i send it to mesh and fluent, I basically tell fluent to keep the surface as wall? If that is the case, I will try this way. Thank you. My question is when fluent asks us to define cell boundary, won't this be considered as fluid? Can we set the surface only as some other material? Or is simply specifying as wall enough for my model.....I apologize if my questions are ignorant, I'm new to this but I'm also excited in learning Ansys.n
      Yes, the term you're looking for is a Named Selection to give the panel a name. You'll finish up with a wall and wall:shadow pair in Fluent to represent the two sides of the wall. The cells are fluid (so air passes under the panel) but the wall (panel) will block flow. nYour questions show you're learning. I'd suggest doing all of the tutorials to get a better understanding of what you're doing. Using the software is fairly easy, using it well is harder. n
Viewing 5 reply threads
