October 10, 2020 at 8:38 pm
carlosjponte
SubscriberHi there, I`m trying to evaluate convergence on my model. It`s a distillation tower in which I want to perform an hydrostatic test. It`s a fluid-structure interaction analysis and I finally got my results with no issues. But when I'm trying to see the convergence chart, it says "no data available". And when I verify the monitors in the structural solver, everything is set as: Structural - chart #3 with: force convergence - displacement convergence - Solution progression and target. (see image attached). Is there something I'm not doing well? I`m also attaching the warnings in case something of this is affecting my solutions. *** WARNING *** CP = 26.938 TIME= 12:56:42 Pivoting has been activated for the Distributed Sparse Matrix Solver . The memory required may greatly exceed the predicted amount. In that event, use the DSPOPTION command to change the memory mode and/or memory size used by the Distributed Sparse Matrix Solver. Distributed sparse solver maximum pivot= 6.356397351E+12 at node 152511 UY. Distributed sparse solver minimum pivot= 2.529365178E-04 at node 97423 UX. Distributed sparse solver minimum pivot in absolute value= 2.529365178E-04 at node 97423 UX. *** WARNING *** CP = 5.281 TIME= 12:56:25 Element shape checking is currently inactive. Issue SHPP,ON or SHPP,WARN to reactivate, if desired. *** WARNING *** CP = 5.719 TIME= 12:56:25 SOLID185 wedges are recommended only in regions of relatively low stress gradients. thank you,
October 12, 2020 at 8:04 am
Subashni Ravichandran
Ansys EmployeeHello Carlosponte
I'm investigating this issue. I will keep you posted on this soon.
October 14, 2020 at 5:24 am
carlosjponte
SubscriberThank you subashni
- Copy user settings to new release
- Electric Heating – Ansys AIM
- Dwg export error
- problem to access on the spaceclaim help
- Unexpected graphics error
- Discovery Getting Crashed
- BUG to correct is important
- Error messages running solver
- Critical error
- Discovery Live freezes with multiple load cases while topology optimization
3660
2534
1745
1226
580
