Is that possible to generate connectivity array by using fluent?
    • wuxuetianzi
      I have a 3d geometry with more than a million elements after meshing. Is that possible to generate connectivity array by using Fluent? If it is possible, how can I do it? If not, could anyone give me some advice?
      Thanks!
      Can you explain in more detail what a connectivity array is and why you want it?
    • wuxuetianzi
      Problem solved, thanks!
