Is the damping value specified by the DMPSTR command related to the value specified by the DMPRAT co
October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeYes, the DMPSTR value is equivalent to 2 times the value specifed by DMPRAT in a full harmonic analysis. See the explanation from development about why we have switched to DMPSTR for Full Harmonic: Prior to the documentation of the DMPSTR command, we *interpreted* DMPRAT as structural damping in a FULL harmonic analysis and included a factor of 2: C=2*DMPRAT/omega*[K]. DMPRAT was never a "damping ratio". When we introduced DMPSTR, it was to clearly state that this was structural damping and to make it consistent with the rest of the engineering community removed the factor of 2: C=DMPSTR/omega*[K].
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
Top Contributors
2656
2120
1345
1118
461
Top Rated Tags
