Ansys Free Student Software
Topics cover installation and configuration of our free student products
Is the LS-DYNA License available with LS-DYNA Student 2020 R2 Download? Need Help with toolbox also.
    • TxPrince
      Below are the License preferences for the prepost and for the solver. The LS-Dyna license is not present in either.
    • peteroznewman
      Did you install LS DYNA Student?nn
    • TxPrince
      I did not know there was a separate section that was not in workbench. From the manual I did not know LS-Dyna had its on tab after you download it, it showed LS-DYNA as a tool in the toolbox in workbench. nThank You! n
    • TxPrince
      I now have the same menu options as you. nI have downloaded ANSYS LS-Dyna Student, but I cannot Locate LS-Dyna. Am I required to download LS-DYNA itself to run the simulations after creating them in LS-Prepost? I can create the models but not run the simulations. How do I get LS-Dyna to work and also appear in workbench? I cant even change the solver to LS-DYNA in workbench. The manual tells you to select the ACT in the Manage Extensions area, but when I select LS-DYNA I still cant run the LS-DYNA program. LS-Dyna Powershell Is not the program btw.nLS-DYNA appears because it is selected in extensions but how do I get LS-DYNA to appear in the toolbox to be able to access LS-DYNA?n
Viewing 3 reply threads
