January 24, 2021 at 10:37 am
uditkumar007
SubscriberHello,nI have written a UDF code for the Herschel-Bulkley viscosity model. nCODE:n#include udf.hnFILE *fp;nDEFINE_PROPERTY(hb_viscosity, c, t)n{nreal viscosity;nreal stress;nreal ys;nreal n, m;nreal k;nreal Max, Min;nn = 0.94; nys = 4.022; nk = 0.04; nm = 1000;nMax = 100000;nMin = 0.00000000001;nstress = C_STRAIN_RATE_MAG(c,t);nnviscosity = ys*(1-exp(-m*stress))/stress + k*pow(stress,n-1);nnreturn viscosity;n}nnI am receiving an AMG solver error when I try to run the solution. Which equation does ANSYS use to calculate the viscosity?nWhen I try to use the in-built Herschel-Bulkley model, I don't get a stable value from the Grid sensitivity analysis. Any kind of help will be very kind.nThanks.n -
January 25, 2021 at 11:16 am
Ansys EmployeeOther than defining the variables as REAL and then giving an INTEGER value it looks OK. Check the maths of the viscosity, and where are Min and Max used? Is the UDF returning a positive value?.If you're not getting a stable result with a refined mesh have a very careful look at the results. You may be finding new details in the flow (ie it's not yet mesh dependent) or your monitors may be picking up some transients in the flow. Hard to say without seeing pictures of the flow field. n -
January 25, 2021 at 12:20 pm
uditkumar007
SubscriberSir, I was receiving a floating-point error too. Maybe the stress was tending to 0 or equal to 0. So the UDF wasn't returning a positive value. So I tried it with an if loop. n{nif (stress<= 0)nstress = 10;n}nnThe solution was running. But I wasn't getting the desired values with this modificationnBut when I changed the Boundary conditions it's running fine. I guess I need to tweak this a little bit to get the desired values. nSir, I am not sure what the max and min value does. I saw this in a reference and also in ANSYS FLUENT 2020R2 there are Max Min And Count values in the strain rate section. Not sure what it does. Thank You Sir for your precious suggestions. n -
January 25, 2021 at 2:05 pm
Ansys EmployeeMost viscosity models have a limit to prevent the fluid value exceeding a sensible range, maybe it relates to that (I've not looked). n -
January 25, 2021 at 6:06 pm
uditkumar007
SubscriberThank You Sir for your kind suggestions.n
5290
3311
2471
