Ansys Free Student Software
Is there a possibility to automate the definition of a moving load in the transi
    • hajar.rhylane
      Good morning all!
      I need to simulate the dynamic response of a beam subjected to a moving harmonic force.
      For that I would need to define for each time step (ti), the node (i) to which the force is applied as well as the corresponding amplitude of the force (F(ti)). This operation needs to be repeated 10651 times.
      My question is is there a possibility to automate this action on Ansys Workbench?
      Thank you very much.
    • Ashish Khemka
      Can you try defining the load as a function of variable 'time' in transient?
      Ashish Khemka
    • hajar.rhylane
      Hello Sir,
      If I define the force as a function, the problem will be defined as a beam subjected to a fixed harmonic force while in my case I treat the case of a beam which is subjected to a harmonic force which moves along the beam .
      Very cordially
      hajar
