Discovery Import
Discovery Import
Is there a way to bond bodies with small gaps?
    • Sungho Jang
      I tried using the contact as below, but it was not successful.
      Is there a way to glue the geometry without pulling it?
    • Charudatta Bandgar
      Hello Jang
      I tried it on my end, and even I am seeing similar behaviour. Let me check, I will get back to you.
      Regards.
      Hello Jang Can you please check the element size in Explore mode, using the "Size preview" option under Fidelity in the Simulation tab? If the gap between your two bodies is less than the minimum feature length that can be captured, it will be detected properly. And since this depends on the fidelity you have used to do the simulation, you can slide it to right, and utilize maximum fidelity and see what maximum gap you can have in between the two bodies, this completely depends on your system specifications, graphic card capabilities and size of your model. On the other hand you can do the same run in refine mode, without any issues. In the attached model, with max fidelity, I was able to capture contact with a gap less than 0.12mm (size preview). Regards.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      • Sungho Jang
        Hello Charudatta Bandgar
        Thank you for answer.
