August 24, 2019 at 3:30 pm
jiamufight
SubscriberI am trying to model the sound generated by a quadcopter and its propagation with the presence of obstacles. As we know, Fluent uses FW-H FW-H formulation to model aeroacoustic nose. However, it is applicable only to predicting the propagation of sound toward free space. So, I am wondering is there a way in Ansys to model the reflective effects of obstacles in aeroacoustic problems?
I come with two possible paths for this problem:
- Compute equivalent sources from CFD solutions and import them into the Acoustic Module to simulate the propagation with acoustic BCs. But, I didn't find a model in Ansys to calculate the aeroacoustic sources that can be imported into Acoustic Module.
- With the FW-H model, also consider the obstacle surfaces as sound sources to account for its reflective effects. I am not sure whether this idea is right or not, as I didn't find available information in the documentation.
Is there anyone who knows how to solve this problem? Which one of the two methodologies might work? Can't believe Ansys was not able to do this. Thanks!
August 27, 2019 at 8:11 am
jj77
SubscriberIf you can export your sources in time domain which should be straightforward I assume to export from fluent.
Then somehow import that into ansys WB and the acoustic act extension that does transient acoustics - again never done this but worth to have ago.
August 27, 2019 at 9:48 am
August 28, 2019 at 2:07 pm
jiamufight
SubscriberThank you! I am working on it
2600
2088
1319
1108
459
