February 16, 2022 at 4:29 am
gogogog
SubscriberHello,
Does Charge solver gives the possibility to set symmetry domain boundary conditions? As far as I know symmetric and anti-symmetric boundaries are available are in FTDF and MODE. Is that the case for Charge? If not, why ?
Thank you.
February 17, 2022 at 1:03 amKhashayar Ghaffari
Ansys EmployeeHi There are no symmetric boundary conditions in CHARGE. If your structure has symmetry you can try reducing the simulation region yourself and scale the results like current manually. You can find an example of this approach in the avalanche photodetector article. Here you can see that only half of the structure is simulated and the current is doubled in calculations done in the script.
Best regards
February 17, 2022 at 11:48 amgogogog
SubscriberThank you very much
- Error on Lumerical device
3694
2564
1765
1234
590
