February 28, 2017 at 9:14 am
Nikita
Ansys EmployeeHow can I select one or more objects, such as faces in SpaceClaim?
July 21, 2017 at 6:11 pm
pgl
Ansys EmployeeYes!
You can select one or more objects quickly and easily by using the Select Tool. Click the first face of your design, hold down the Ctrl key, and then click each individual selection you want to add to or remove from your original selection. For more information, refer to the SpaceClaim Online Help.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2116
1337
1118
461
