Is there any difference between pathlines, streaklines and streamlines?
    • Karthik R
      Administrator
    • prajput
      Hi @Kremella  ,
      A pathline is the path or line or trajectory traced out by a single moving particle.
      A line joining all these fluid particles which pass through a specific point in space is referred to as a streakline.
      Streamlines are lines in the flow field such that at a given instant of time are tangential to the velocity vectors at every spatial location in a flow field. Hence, the flow cannot cross a streamline.
    • Keyur Kanade
      Hello @Kremella , In simpler terms, A pathline show the trajectory of a single particle over time. A streakline is typically used in experiments. Releasing ink in water at a specific position, we practically mark the particles passing at that location. After some time, these particles would be at different locations. The line formed is a streaklineStreamlines are lines tangent to the local velocity of the fluid. They are obtained using only the velocity vectors at a given instant of time.
    • prajput
      Btw one note to add. For steady flows they are all the same, while this is not true for unsteady flows.
Viewing 3 reply threads
