Is there any way to import External Data at different time steps and into different deformed shapes?
March 28, 2022 at 5:18 am
Alexander19
SubscriberHello,
I'm trying to import Temperature profiles into a rod deformed at times t0,t1,t2, respectively using the External Data module.
The rod is deformed as shown in Figure below.
March 28, 2022 at 1:58 pmMarch 29, 2022 at 1:35 amAlexander19
SubscriberThank for your reply I know this option but it is used for controling the time steps only. When we want to import data from External Data, these data will be imported before starting the calculation . Thus, those data can be applied ONLY into the INITIAL shape of the wire.
March 29, 2022 at 12:54 pmRahul Kumbhar
Ansys EmployeeOne workaround would be you can import the temperature in steady state model and then export the csv file. But for this export, use node numbers instead of xyz location.
Ansys Innovation SpaceTrending discussions- Saving & sharing of Working project files in .wbpz format
2610
2088
1319
1108
459
