March 26, 2021 at 4:43 am
ibopaul
SubscriberHello, I'm using Ansys Fluent 2021 R1 student versionnMy target simulation is steady flow with transonic flow on airfoil, so I used density based coupled solver.nAfter checked every input on calculation, in the Run calculation tab, I found that I can modulate CFL number on solution steering tab. (stage 1 and stage 2)nMy question is can I linearly increase CFL number in some iteration interval?nfor example, from 10 to 100 iteration, increasing linearly with initial CFL number to maximum CFL number.nThere is update interval tab, but I think this is not appropriate function for change CFL number linearly.nnThank you.n -
March 26, 2021 at 6:01 am
DrAmine
Ansys EmployeeIf you are talking about steady state solution steering I guess no. n -
March 27, 2021 at 1:24 pm
YasserSelima
SubscriberYes it is possible using UDFnAll variables you set in the GUI could be changed from your UDF through RP_Set_Real ... and define_adjust is recalled every iteration ... So, if you are able to know the variable name, you will be able to modify it every iterationn -
March 29, 2021 at 3:22 pm
Ansys EmployeeYou can trigger solution steering based on iteration, but that will be step changes over a gradual increase. n -
March 29, 2021 at 4:44 pm
ibopaul
SubscriberThank you for comments!!n -
March 30, 2021 at 5:22 am
DrAmine
Ansys Employeethat is wrong. If steady-state density based + solution steering the only way via scripting deploying some scheme functions (if this high level is required).n -
March 30, 2021 at 12:57 pm
YasserSelima
Subscriberif you don't know how to do it, ask.n
Viewing 6 reply threads
Trending discussions
Top Contributors
2564
2068
1289
1106
459
Top Rated Tags
