December 2, 2020 at 8:22 am
Nicolo
SubscriberHi,
I have performed a simulation on Steady state tubulent flow of air. My residuals are as flowing. I have also checked the pressure in my inlet (as control point and it is steady) it changes a few Pa in each itteratioin.
the fact that my mass residuals are so high (3e-2) means my simulation is not converged and I cannot use the rsults? (despite that other parameters reached 1e-5 in residuals?
December 2, 2020 at 11:03 amKeyur Kanade
Ansys EmployeeResiduals does not necessary define convergence. Please create a monitor for a variable like outlet temperature etc and check the convergence. nPlease search on forum for similar posts. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynDecember 2, 2020 at 11:14 ammese
SubscriberHi,nYes, the mass residuals are so high and that may (but not necessarily) imply that the results are invalid or highly inaccurate. Without knowing the details of your model, I cannot say what the cause is and how significant is its effect on the results. nDecember 2, 2020 at 1:18 pmKeyur Kanade
Ansys EmployeeThanks nAppreciate your response. nWe encourage users to participate more in the forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 3 reply threads- The topic ‘is this simulation converged?’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1682
1474
