Isolate the Total Deformation Chart in a structure subjected to lifting
    • mateusr
      Dear all,
      I'm simulating the lifting of a structure (by 4 points at the top of the frame). The lifting point that connect the 4 wires and works as my constraint is not aligned with the CoG of the structure, hence when I analyse the Total deformation result, the software gives high values of deformation due to the movement of the structure around the lifting point.
      From a visual inspection, I do not have high deformation and when i plot the contours with the undeformed mesh, I can assume that the deformation is just a consequence of the movement of the structure, and not a proper problem in the structure.
      Can I individualize just the deformation of the structure, without considering the rotation around the support?
    • Nima
      Isn't it possible to create a new coordinate system attached to the structure and then compute the Directional Deformation results with respect to the new coordinate system?
    • mateusr
      I'm not sure, but in any case the suggestion is good. If I could implement this, the problem is solved.
      Thank you for your suggestion.
    • mateusr
      Unfortunately, it didn't work. Even if the coordinate system is attached to the structure, when I plot the deformation it remains in the original position and didn't provide me the values that I want.
    • jj77
      You want to plot displacements relative another point (have in mind stresses are OK do not need any rel.).
      I have done this in other software - here is something that will help on how to do this
      http://www.padtinc.com/blog/wp-content/uploads/2018/04/PADT-ANSYS-Mechanical-Extracting-Relative-Displacements-20180404.pdf
      Also perhaps in a user defined results subtract the displacements that you want.
Viewing 4 reply threads
