Issue in creating the Volume Domain in Space Claim
    • skdubey
      I am trying to extract the fluid domain from my geometry using the Spaceclaim. I found that the domain couldn't form due to some clearance or giving me the error " Can not create a volume body -all ends have not been capped".
      A. I tried to check the clearance in the solid work assembly my body is concident have "0" clearance. Not sure, what to do,
      B. Even the fluid domain, couldn't able to capture true interior cad shape any suggestion?
      Any help will be really appreciated.
    • Keyur Kanade
      Please check geometry in SpaceClaim.  Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM) The geometry should be error free to proceed.  If geometry has any errors, please modify/recreate geometry at those places.  Please check Combine → Merge option and try to merge all bodies. Then try to extract fluid volume. Please check https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=video&cd=&cad=rja&uact=8&ved=2ahUKEwj05fTHh6L4AhWWAKYKHQCdBjUQtwJ6BAgKEAI&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DJp8btI0PCyU&usg=AOvVaw0FA-QhMbb-o13knTuKgg15 Regards, Keyur
    • Keyur Kanade
