Issue loading case files into Fluent
    • Lukáš Trizuljak
      Is anyone able to help me with this error message? I try to load a case into Fluent from a class and this error keeps popping up:
      Reading mesh ...
      10000 cells, 1 cell zone ...
      10000 quadrilateral cells, zone id: 2
      20425 faces, 5 face zones ...
      19575 2D interior faces, zone id: 3
      400 2D symmetry faces, zone id: 4
      25 2D velocity-inlet faces, zone id: 5
      25 2D pressure-outlet faces, zone id: 6
      400 2D wall faces, zone id: 7
      10426 nodes, 1 node zone ...
      Done.
      Error: EOF in string read
      Error Object: ()
      Error: api-get-var: the object is not active
      Error Object: setup/general/solver/time
      Real overflow
      Real underflow
      Real overflow
      Real underflow
      I'd be grateful for any help.
      Thanks!
      Forum Moderator
      Which version of Fluent were you using in class, and which version are you reading it into? The mesh may be OK, but the api-get-var suggests there's something missing that's model related.
