Issue regarding Setting Up a Dynamic Mesh Problem in Fluent For a Piston and Reed Valve Parts I
    • baharaksajjadi
      Hi, i have been trying to use the setup of the piston and reed valve by ANSYS(
      " target="blank">
      ) and i am having hard time finding the files that could be used to understand. The tutorial by ANSYS lacks the geometry files and its dimensions, the meshing procedure and the setup lacks the UDF files and the profiles. How does ANSYS expects us to follow the tutorials without providing sufficient files or tutorial video that could be used for the same.
      I am herewith specifying the files needed:
      Geometry
      Meshing and procedure
      Setup - UDF and PROFILE files
      I hope if the team could help provide the details required if any such files exists. thanks
  • Keyur Kanade
    As Ansys Staff, we can not download attachments. Please upload images using upload image functionality.
    Please check help manual for some tutorials.
    Ansys Help
    Regards Keyur
  • baharaksajjadi
    I have attached images for your reference. Yes, i have seen help manual and i could not find anything that concerns.
    I just needed a clarity, why does ANSYS post a video without much information? As you can see in the post, the whole setup is great but the crux of the whole dynamic meshing is missing. Anyways, if you could help me in any way possible, that would be great.
  • Keyur Kanade
    Creating profile is custom task. The main aim of video is to show procedure
    Please check Profile section of help manual and you can create profile on your own.
    Regards Keyur
  • Viewing 3 reply threads
