issue trying to mesh hexahedra on simple shape
    • Sebastian Pearson
      I'm trying to mesh simple bracket, and want all of the elements to be hex elements, however I keep getting tet elements, or the mesh fails to generate when I change the settings. I've added seeding which to me makes it look pretty straightforward to mesh hex elements. Is there anything I can do to fix this? Is there some way to force hex elements only, as that should do the trick?
      Note: I've got experience meshing on similar software such as abaqus and I found it pretty easy to do the hex meshing on this shape there.
    • Ankush Choudhary
      Hi Sebastian,
      Can you please try changing the mesh method from automatic to MultiZone?
      For further information, please follow Ansys documentation on MultiZone meshing.
      Thanks,
      Ankush
      • Sebastian Pearson
        Thanks for the reply Ankush. I tried that before and I think it generated something, but the hexahedra werent uniform rectangles which is what i was hoping for, and is the type of result I have managed to acheive on other FE software.
