Ansys Products
Ansys Products
Issue while working on network files
    • Matt Bowman
      Our users are running into these errors when working on files using our file server. Permissions to the folders they are using are correct and they have read/write access. However, these errors do not pop up when working on the files on the local disk.
      Any suggestions will be appreciated. We are running Ansys 2022 R2
    • Gary Stofan
      Hi Matt
       The error messages are not consistent with a file / file system / permissions issue.
       For example, Structural results are written to file.rst. If this file is not found at all, then a messge Results file not found is triggered.
       In your case the file.rst was likely found, but did not contain the result quantities being asked for. A user can enable/disable various output quantities in the Analysis Settings > Output Controls.
      If you can provide any additonal error messages or information, please provide them as it will give us a better idea of where to look for your issue.
