Discovery Import
Discovery Import
Issue with 19.2 Installation
    • hashan.mendis
      So I installed Discovery 19.2 as a subscription. Worked fine.
      I then installed Workbench 19.2. When I try to run Discovery it tells me there aren't licenses in the licensing pool.
      I didn't ask for floating but after workbench is installed its overriding something in the background.
      Do i need to install Workbench first and then Discovery?
      Or
      Install Discovery and Workbench in different directories. (i left the install directory as default - c>programfiles>ansys inc for both)
    • Naresh Patre
      Hello  hmendis
      I first installed Workbench in default location and then installed Discovery products in a different drive. This is working fine for me. Can you try it out?
      • hashan.mendis
        Naresh Patre I did try that and it did work for me.
        Can this please be fixed in the future? I can see some clients having this issue.
      • Naresh Patre
        hmendis I have submitted a defect for this issue. Below are the details:
        Defect Title: Problem installing Discovery R19.2 along with Workbench R19.2
        Defect found in Release: R19.2
        Defect ID: DE179115
