April 20, 2023 at 6:17 am
Francis Poussin
Ansys EmployeeAECs = Ansys Elastic Currency
If you are using AECs with 2023R1 on Ansys Gateway, you will need to install manually 2023R1 Service Pack 2 on the Virtual Machine.
This is because there is a problem with how AECs are calculated in 2023R1. This problem is resolved in the Service Pack 2 which will be automatically part of the package installations from May 15th. Until then, the installation of the SP2 has to be done manually.
Here is an article explaining how to install the Service Pack 2
If you are not using AECs, you will not be impacted by this issue.
- (0x8007052E): The user name or password is incorrect
- Some of the instance types are greyed out and cannot be selected.
- Ansys Gateway powered by AWS – Minimum Technical Skills
- ADConnector Installation Fails due to .NET
- Unable to install Service.
- About Multi-domain support
- What is the average time to set an HPC cluster up?
- How does metering work?
- How do I enable multiple screens in an RDP session?
- Welcome to Ansys Gateway Powered by AWS
5290
3311
2471
