October 20, 2022 at 1:27 am
rakesh_krishna
SubscriberI am running the CROW lumerical example and after figuring out Kappa1, and 2 from interconnect simulations, I tried to run the FDTD file to calculate the gaps. But the high accuracy and coarse mesh sweep for gaps yield different curves. Furthermore, running the "calculate gaps" script file yields negative numbers for the gap. What could be the reason for the strange numbers/values and the difference between the sweep outputs?
For example, the S41 from both these sweeps are different.
October 20, 2022 at 5:54 pm
Guilin Sun
Ansys EmployeeFDTD is a discrete method;
the result shows that the coupling is very sensitive to the mesh in the gap.
Please note that the s parameter is complex. it can be negative.
Please do some converging tests:
Convergence testing process for FDTD simulations - Ansys Optics
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8824
4658
3155
1688
1482
