January 16, 2023 at 6:25 pm
Steve Long
SubscriberI'm having an issue with displaying E-Fields. I'm running an HFSS Transient Composite Excitation simulation. My simulation consist of two parallel plates with a voltage transient across one end of the plates and a resistive load across the other end of the plates.
First, I plotted the voltage across a load. Then, I added a sheet to bisect the plates and created a facelist from the sheet. I also updated the analysis setup to save fields. I reran the simulation and the voltage plot is now different than it was prior to adding the sheet. It looks like adding the sheet to the model affected the results of the simulation.
Is there a way to add a sheet for viewing the E-Field without affecting the results of the simulation?
- 2022 R1 What’s New PDF/PPTX?
- Prms/ pmean
- separation based debonding,CZM parameters
- Hydrodynamic diffraction and response
- The simulated results of microstrip patch antenna does not match the online example
- Desktop/laptop specification for Ansys forte
- how to simulate piezoelectric patch on ANSYS workbench ?
- Heat simulation – change source wavelength
- Meshing/Simulation problem
- Mudjere
2630
2110
1335
1110
461
