June 21, 2020 at 4:38 pm
June 21, 2020 at 7:54 pm
albuspotter
SubscriberI have also tried only using one fixed support with all four faces selected. Even in that case, I am encountering the same issue.
June 22, 2020 at 12:23 am
SubscriberIt looks like you have multiple bodies and are relying on bonded contact to hold things together. If you insert a Contact Tool under the Connections folder and Evaluate Initial Contact Status, you might find that some of the contacts are not closed.
June 22, 2020 at 9:23 am
albuspotter
Thank you so much! I did the required changes and added contacts and now it runs perfectly.
3744
2573
1809
1236
594
