November 25, 2019 at 6:51 am
jvardaman
SubscriberWe have a fairly simple model in HFSS. It is a circular copper strip placed symmetrically around a single steel ring. The copper strip is excited via current excitation at 13.56MHz. I would expect the electric and magnetic field to be symmetric around the ring. However, there are nodes in that cause it to be very non uniform. We have increased the meshing to the max, but the results weren't much better. I have images, plots, and the model files that I can share if requested. I just want to figure this issue out as it's been a big snag for us!
- Maxwell, HFSS or Q3D?
- Error
5340
3327
2471
