Issue with Imported Cut Boundary Constraint
    • jonl
      Hi! I'm trying to do an analysis on a submodel but the imported boundary constraint is misbehaving. The imported load is shown exactly as it should be, but the deformation in the analysis at the cut boundary doesn't match at all. Why isn't the imported boundary constraint matching the deformation?
    • peteroznewman
      For me to look more closely at this issue, use File Archive to create a .wbpz file. Use a file sharing site such as Google Drive, Dropbox or Jumpshare (which is what I use) to upload the .wbpz file.
    • jonl
      This is work related, so I don't want to share the archive. I've worked around the problem by solving the entire geometry instead of submodelling. Still find it stange that the submodel would behave like that.
    • peteroznewman
      I haven't used the submodeling feature myself as I have a large enough computer to solve the whole model.
Viewing 3 reply threads
