September 14, 2022 at 8:42 am
U Abinash Patro
SubscriberWhen I am trying to import a radially polarised source(generated the .MAT file from a code I got in lumerical website) using the import source option , Initially I am able to visualise the distribution of electric field vectors just after impoting the data , but when I try to apply and ok while setting up the simulation and running it, I am unable to get any electric field data. Can anyone can comment regarding this?
September 14, 2022 at 9:10 pm
Guilin Sun
Ansys EmployeeDo you want to get the importd source data, or want to visualize the source data? Do you find any result in other monitor? Please make sure you save it correctly. you can close the import tab and reopen, then visualize the data to see if it is normal.
September 15, 2022 at 5:30 am
U Abinash Patro
SubscriberFirst I import the source and visualise it, everything seems fine i.e; I can see the electric field vectors in a radially outward way for a radially polarized source. Now just after clicking 'OK' for saving the data in the simulation, I reopened the source properties and clicked on visualise the data but it is showing source not imported.
Also after I run the simulation, I tried to see monitor data and there the electric field was 0.
September 15, 2022 at 4:23 pm
Guilin Sun
Ansys EmployeeI believe you need to update the FDTD version to the newest 2022R2.2.
I tested and did not find any issue regarding to the source import.
You may need to have a clean installation: https://optics.ansys.com/hc/en-us/articles/5613618572947-Fixing-installation-or-license-activation-issues
clear all related folders, including hidden folders, restart your computer, reinstall, and test again.
- 软件打不开
- Ganhemt Project mistake can you help me
- how to export results from SPEOS to Mechanical
- Simple Optical simulation
- How to calculate the cross-polarization efficiency and phase in FDTD
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Negative Reflection Problem
- Inverse design of polymer y-branch – modify the example provided
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
2720
2146
1357
1150
462
